battery draining rog 6d
sean25
can you guys help me ive been having this problem since i bought the phone the battery is draining so fast even when i updated it to the latest fw do you guys have any solutions?
Smokee_024
Well set to screen refresh rate on 60hz if your battery drains a lot faster than usual.well usually phone takes upto 1 to 2 week to analyse your battery usage pattern so no need to worry and use bypass charging feature while you play a game.
6d_hype
Asus+mediatek moment mine also have worse battery life than i expected for a 6000mAh phone even light gaming on this phone uses a lot of power
yikes have you solve the solution?
