My Asus Rog 5 phone shutdown at 40% battery. What's the solution
andrehewittalex
Model Name: Asus Rog 5 phone
Firmware Version: I005DA
Rooted or not: not tooted
Frequency of Occurrence:
13 REPLIES 13
NatanK
k_huat
Pls go through the discussion n recalibrate your battery
Step1: go to "Settings" > "Battery" > "Battery Care"> "Select charging limit"> "Move bar to 100%" , and turn on "steady charging" n choose "ultra steady"
Step2:Plug in AC charger to charge battery to 100%
Step3:Normal use until capacity of battery decrease to 0%
Step4:Do Step 2 again to charge battery to 100 %
I'm now avoid using the phone below 20% n will charge it when around 30 %
im facing the same problem on my rog 5s. I hope it works.
k_huat
Rising Star II
NatanK
https://zentalk.asus.com/en/discussion/comment/199648#Comment_199648
Follow the steps above n problem solved buddy
NatanK
k_huat
https://zentalk.asus.com/en/discussion/comment/203538#Comment_203538
it works!! thank you 🙂
Gustav_ASUS
Community Legend III
I will lock this thread and leave a short SOP for other users facing this issue:
Go to: Settings -> Battery -> Battery Care -> Select charging limit -> Move bar to 100 %
Plug in AC charger and charge your battery to 100 %
Use your device until the battery is completely drained to 0 %
Perform step 2 again to charge your battery to 100 %
