Headphone Jack Issue- crackling sound
KevinTsuna
Model Name: Rog 5 16gb
Firmware Version: WW 1226.139-0
Rooted or not:Not
Frequency of Occurrence: Sometimes
APP Name & APP Version (If your issue relates to the app): Any app that outputs sound
When connected to the headphone jack and playing music/watching videos, the phone outputs a crackling sound/noise together with the sound it's supposed to be playing. It doesn't do this when using the speakers. I've tried using different headphones but the issue still occurs from time to time, especially when the volume is more than 50%.
Headphones used:
Sennheiser HD 58x
Phillips SHP9500
The issue might be similar to this: https://zentalk.asus.com/en/discussion/63944/crackling-sound-from-headphone-jack-on-high-volume
Cheers,
Kevin
5 REPLIES 5
login078
This happens to my RoG 5 8gb too, during heavy gaming sessions after android 12 update. Never occurred while using speakers. To remove the static noise, i unplug and plug my earphones. I tried ".12345+=" on calculator to test and my 3.5mm jack works fine for now.
keren_ASUS
Hi Login078,
Can you help us out and share a log of this issue? You can share the link on this post.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
KevinTsuna
The frequency of the issue occuring is increasing recently. I tried screen recording but it won't capture the crackling sounds. Even if I hear it, it won't be recorded and will occur at different times in the duration of the screen capture. Unplugging and plugging the headphones back don't resolve the issue. I think the crackling sound started after the release of Android 12. I don't think I've encountered this prior to the first A12 update.
KevinTsuna
Addendum:
Using a 3.5mm USB dongle won't replicate the issue. So the problem must be the headphone jack/ or software related to the headphone jack.
