11-13-2021 03:10 PM
11-17-2021 02:12 AM
jin_akiranope, none of that tencent sht. also i've mentioned that i used the original charger and cable, but still no hypercharge, not even charging at all. and unfortunately i don't have a spare asus rog phone charger.One thing for sure is the HyperCharge will only work on the official ROG Phone charging brick and won't work with other 30w and above charging brick as the HyperCharge is proprietary. Doesn't matter if the charging brick supports 60w or 100w, it will still be capped at the next available fast charging speed which is Power Delivery at 10w / 12w / 15w (if i am not mistaken, someone please correct me if i am wrong).
I am on the same firmware and am able to get the HyperCharge speed on my original ROG Phone charging brick and original cable. Did you use a different cable by any chance? Would it be possible for you try on another ROG Phone charging brick? Also is your unit a Tencent unit?
11-22-2021 02:16 AM
11-26-2021 04:20 PM
11-27-2021 01:51 AM
