05-24-2021
10:54 PM
- last edited on
01-16-2024
01:06 AM
by
ZenBot
06-01-2021 11:19 PM
06-02-2021 08:19 PM
feriooneI presume when you said you tried different settings, that includes resetting to factory default then redo all the system setup, tried with different versions of firmware, tried swapping the primary AiMesh router, etc.Same issue on the latest Version 3.0.0.4.386.43170, I’ve been struggling with my 2.4 wifi disconnect issue for about 6 months since I bought the zen wifi mesh. Some device will recover while some will just not be able to communicate at all. Previously with my netgear I did not have any of this problem. Tried many different settings but still the same issue. The app will show it is still connected with good rssi value, but ping will not respond. Reboot always fix the issue but I need to reboot every 1-2 days just to have all device working. Tech support never responded to me, this is definitely my last ASUS router I will be buying.
06-09-2021 02:19 PM
01-18-2023 12:26 AM
Happened to me after my mesh auto-updated to 3.0.0.4.388.22068. Downgraded to 3.0.0.4.388.21617 and the problem went away.
Disturbing that this bug seems to crop up again and again.
Also noted that the router admin web pages became very, very slow. Again downgrading resolved that.
