Wifi problem after sleep mode
Goffy
Detailed description:
Hello, I've been having a problem with my wifi for a few weeks now and I haven't been able to solve it
Sometimes I put the computer to sleep and when I come back to it after a few hours I find that the WiFi is down and I can't use the WiFi unless I restart the computer
I can see the Wi-Fi sign and I can turn it off and on but it doesn't show me which network to connect to and it says "unavailable"
9 REPLIES 9
Falcon_ASUS
Goffy
https://zentalk.asus.com/en/discussion/comment/235366#Comment_235366
Are you facing the same problem?
@Goffy
Will the situation improve after reinstalling the WLAN driver by referring to the FAQ?
Goffy
Falcon_ASUS
https://zentalk.asus.com/en/discussion/comment/235369#Comment_235369
@Goffy
No, unfortunately, I tried that, but it didn't work
Falcon_ASUS
Goffy
https://zentalk.asus.com/en/discussion/comment/235441#Comment_235441
@Goffy
If the problem persists, I would recommend you to back up your data and restore the system.
[Windows 11/10] How to reset the PC and remove all of my personal files, apps and settings | Officia...Sorry for any inconvenience it may be caused.
Goffy
Hello. Have you been able to solve the issue? If yes, please let us know the possible solution. Thank you! If no, one way to manage the issue without restarting the computer is to run the network troubleshooter. It will bring wifi back by, I think, restarting the network adapter.
ASUS_Bot
Rising Star II
