ROG Rapture GT-AX6000 Merge Speed for 2 routers & Wan Aggregation
we have 2 Internet 5G router which each router having speed 400mbps so we are using ROG Rapture GT-AX6000 router so we need to configure as Wan Aggregation and we need to merge both Internet router and should give speed after router 800mbps kindly suggest it we did setting as wan aggregation and all as per manual but its not giving merge speed getting only 1 Router speed..
Falcon_ASUS
@kapil2023kalal
Here we mainly discuss the issues/questions related to ASUS laptop.
For your Router questions, I suggest you contact our local call center to have further assistance.
Please refer to below and find the link of local call center.
ZenBot
Community Manager
Community Manager
