2 hours ago
I've bought a zenphone 10, less than a month ago, and I've been facing several issues with the wifi conection, I hoped it was a software issue that fo away with updates but is still ongoing.
I've noticed this with several apps, like Garmin connect, reddit or Spotify. I open this apps and they seem stuck, sluggish, or don't show information. When I turn wifi off, the apps instantaniously update and work correctly. If I turn the wifi on again it seems ok for a while, but it soons returns to the same.
This has been happening in several houses (different conections) and different routers, and it seem specific to this phone.
Is there any solution?
Thanks
