Problem with last firmware
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-15-2019 07:39 AM
Model: ZE520KL
RAM: 4GB
Firmware/App Version: WW_15.0410.1807.75
Frequency of Occurrence:
Rooted: No
App Name:
Description: Problem with last firmware URGENTLY
The latest version of oreo (shown above) has several bugs: -the flashlight / flash does not always work, everything is solved by restarting the phone, and it is a software problem, because with older versions of Android and other roms this does not occur -the bluetooth shortcut in the notification center does not always work, sometimes it is not clickable -once connected a bluetooth audio device, sometimes it is not possible to raise the volume because it does not recognize the device, and therefore it raises the volume of the audio but not of the music (in call or music playback the volume is low and you need to pair the device again, or delete the Bluetooth app data to fix) -poor wifi signal or that disconnects often, with other smartphones does not happen at equal distance -last security patch July 1, 2018 (you promised to reward them) -on italian smartphone, there is a wrong translation on menu connection, where CHIAMA should be IMPOSTAZIONI DI CHIAMATA ASUS, FIX IT because with these bugs the use of the smartphone is impossible, otherwise I will proceed by legal means
RAM: 4GB
Rooted: No
App Name:
0 REPLIES 0
