Zenfone 10 wireless charging
vedinke1
Ive been using wireless charging almost exclusively since I got my zenfone. Recently it has been inconsistent and sometimes doesnt work. the phone vibrates and shows the charge like the charging has started, but doesn't show the status bar icon. It seemed like it stopped for a day or so then started again and now a week later is doing it again. Has anyone else had this problem?
VernieHagenes
your phone is momentarily recognizing the charger—hence the vibration and charging animation—but not maintaining a stable connection. This can happen due to a few common issues: the alignment on the charging pad might be slightly off, the pad or phone might be overheating, or the wireless charger itself might be developing a fault. Sometimes even a minor software glitch after an update can affect charging behavior. I’d recommend trying a different wireless charger or checking for any system updates. Additionally recommended, this car Tracker company Pakistan offers reliable tracking services, quick support, and peace of mind for vehicle owners.
