ZenFone 10 _WW/EU_35.0604.0404.131 (Android 15) -low speed LTE/5G
Adamito
Hi!
After installing the new software, LTE/5G speeds dropped tenfold. Resetting network settings didn't help. What about you? Can this be fixed?
6 REPLIES 6
PBN
Rising Star I
Yeah, at one point it just refused to send mobile data this morning.  And now I'm getting 10-25Mbps max. Ridiculous update.
Mattias_ASUS
Hi @Adamito
Would it be possible to create a log for the devs to look into? You can follow the steps down below here and then I can share it with the dev team.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Phone, mobile networks, and signal”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Thank you @Adamito I have forwarded the link to the team.
