Zenfone 11 ultra power setting and slow fota
Mizuki115
So I just test the zenfone 11 ultra and I found that changing the power setting like dynamic,full performance and power saving without a full restard is sometimes not working, I usually used the power saving for when I want to play game without excessive heat, but now I need to restart the phone whenever I want to change the power setting, but sometime it work as normal.
And FOTA for zenfone 11 ultra latest update. Where is it ? Its been 1 week, the kernel is released but I cannot installed it because its a kernel and not a firmware.
Im still at the WW 35.120.1420.112 and no new FOTA, 2-3 days before released ok, but now its been 1 week.
jimlopens
It sounds like your Zenfone 11 Ultra’s power mode switching issue might be a software glitch rather than a hardware limitation. Normally, switching between Dynamic, Full Performance, and Power Saving modes shouldn’t require a restart, so the fact that it’s inconsistent could point to a bug in the current firmware. You might want to try clearing the PowerMaster app cache (Settings → Apps → Show system → PowerMaster → Storage → Clear cache) and see if that helps until the next update arrives.
Regarding the FOTA — the WW 35.120.1420.112 build is still the latest officially pushed to most regions. Even though the kernel source is already released, that’s mainly for developers and doesn’t mean the firmware is immediately available for public OTA. ASUS often staggers the rollout over 1–2 weeks, so you might just not be in the first wave. Keep checking Settings → System → System update or the official ASUS Support page for your exact SKU/region. If you don’t want to wait, you can manually download and install the firmware from ASUS’s support site once it’s posted for your variant.
Mattias_ASUS
Hello @Mizuki115
Are you still having issues with the FOTA? It's normally a rolling process that might take about a week.
