System: Battery or AC: Model: Frequency of occurrence: Reset OS: Screenshot or video: ======================== Detailed description: whenever I move my laptop in the slightest it shows on battery and then reverts back to plugged in this is very irritating because I cannot move my laptop because this keeps on reverting back and forth.
Hi there, Which model do you have? It is very likely that there is some issue with the hardware, either on the cable, or the power port on the device. Please kindly send the device to our service center. Thank you.
Hello Ranjana, This is more likely to hardware issue with the power cable or power IO port. Please kindly send the device to our service center to check. Thank you.
