MyAsus hardware issues
escapegoat
System: windows 10
Battery or AC: default
Model: TUF Gaming FX505GT
Frequency of occurrence: always that I check
Reset OS: it's not in my plans
Serial number: KBNRCV02245046B
Detailed description:I want to know what is wrong, the pc or the app, since I bought the laptop, it comes with the adapter issue, the fan issue is new
5 REPLIES 5
Blake_ASUS
Community Legend II
Hello escapegoat,
May I know the version of My ASUS APP and ASUS System Control Interface V2 driver on your device?
escapegoat
óf course, My ASUS APP's version is 2.2.38.0 and System Control Interface is V2 2.2.27.0
Blake_ASUS
Community Legend II
Hello escapegoat,
Please kindly help to update to
MyASUS v2.2.41.1 & ASUS System Control Interface v2.2.29.0.
Thank you so much!
escapegoat
ok, it seems that the adapter already works fine, but I still have the fan issue.
I have also verified that the laptop increases the temperature if I have it charging, if I disconnect it the temperature decreases almost 10 degrees, is it normal?
