GPU STUCK AT 210Mhz ON BATTERY
Zenitsu
Hello
I have Asus Tuf F17 FX706HF with rtx 2050, When i start my laptop gpu is unstable, sometime gpu in power saving mode, sometime stuck at 210Mhz
Seriel No. R4NRC**********
I purchased laptop only 2 months ago
And if gpu not going into power saving mode then CPU stuck at 1.2 Ghz, i have a big problem of slow system because of this,
Provide solution
Falcon_ASUS
@Zenitsu
May I inquire if your current operating system build number and BIOS version have both been updated to the latest versions?
Have any changes been made to the power settings options, or are they still set to default?
Please ensure that both the system version and BIOS version are updated to the latest, and provide their respective versions to us.
Additionally, kindly provide a screenshot of the power settings for our confirmation. Thank you.
Os build Number: 22621.2361
BIOS :307
@Zenitsu
Since you are already using the latest versions, we would recommend backing up your data and performing a system restore to eliminate the possibility of instability in the system.
[Windows 11/10] How to reset the PC
If the issue persists, we recommend sending it for repair.
