01-16-2025 10:37 AM
I've 4 BT8s configured in router mode and connected with an ethernet backhaul. My iPhone 14pro and my Mac (M2) frequently (daily) enter in a loop of connection and disconnection from Wifi (every 2-3 seconds). This happens also if I'm in the same room of the main router or of a mesh node.
I've a standard configuration with a single SSID.
The only way to mitigate the problem is to delete the network from my iPhone configuration and configure it again.
What can I do?
02-08-2025 12:38 PM
Yeah I haven't seen the issue since switching to the Beta firmware - looks like it's on the website too now:
02-09-2025 12:11 PM - edited 02-10-2025 04:15 AM
@deiacovo applebees wrote:I've 4 BT8s configured in router mode and connected with an ethernet backhaul. My iPhone 14pro and my Mac (M2) frequently (daily) enter in a loop of connection and disconnection from Wifi (every 2-3 seconds). This happens also if I'm in the same room of the main router or of a mesh node.
What can I do?
Try updating your BT8 firmware, separating 2.4GHz/5GHz SSIDs, checking Wi-Fi channels for interference, adjusting DHCP lease times, and ensuring proper mesh node placement. Also, test manual reconnection and ensure iPhone/Mac software is updated.
02-12-2025 12:31 PM
@Aureliannn_ASUS this evening the problem presented again. Same symptoms with a connection and disconnection loop
02-18-2025 01:00 PM
@Aureliannn_ASUS exèperienced the issue again. Set the log though roter's UI.
02-22-2025 12:22 PM
Still having issues with iphones disconnecting with the beta firmware here... I haven't gotten caught in the loop but continue to have an issue where the phone disconnects then can't reconnect manually- it gives an invalid password error.... Have to reboot the phone or switch to the Iot network and back to get back in the main network... I really hope they fix this soon; annoying to keep having connection issues almost starting to regret ditching my ISP router- it was slower but more stable connections.
