03-24-2025 01:55 PM
I've had an issue ever since upgrading my mesh system from 3 RT-AX92Us to 3 ZenWiFi BT8s...I'm frequently getting popups in Chrome that the "Page is Unresponsive". I can either wait 10-15 seconds, or hit the OK button and continue, but I'm concerned that the routers/mesh is having momentary pauses. I also notice that oftentimes my iPhone will seem to freeze while trying to pull up a web page, but if i turn off WiFi (so that I'm only using cellular data), the page will load up just fine.
How do I find out what my router/mesh system is doing and why there are pauses in my connections?
03-27-2025 06:30 AM
Thought I'd add the 'wait' message:
03-27-2025 11:08 PM
Hi @Steve76063 ,
Regarding the issue you are experiencing, we recommend following the steps in the FAQ below for troubleshooting.
[Troubleshooting] Failed Internet access through router | Official Support | ASUS Global
If the issue persists after confirming all the steps, please use the system to submit a problem report at the time the issue occurs.
Please follow the steps below to report the issue, and we will assist you:
Additionally, please send us the following information via private message: product serial number, the time the problem report was submitted, the email used for the problem report, the time the issue occurred, the MAC address of your device, and a network architecture diagram of your current environment.
If your network is down, the UI page will generate a link for downloading offline data. Please click the link to download the data, compress it into a ZIP file, and provide a cloud link for us to analyze.
Thank you for your cooperation.
