01-16-2025 10:37 AM
I've 4 BT8s configured in router mode and connected with an ethernet backhaul. My iPhone 14pro and my Mac (M2) frequently (daily) enter in a loop of connection and disconnection from Wifi (every 2-3 seconds). This happens also if I'm in the same room of the main router or of a mesh node.
I've a standard configuration with a single SSID.
The only way to mitigate the problem is to delete the network from my iPhone configuration and configure it again.
What can I do?
02-25-2025 02:28 AM
@Aureliannn_ASUS just to know if there are some news. Thanks
03-23-2025 12:32 AM
Hi, I can confirm that I have the same problem (I've had two Bt8s for a week and I have the new firmware installed). I have no problem with any device at home including iPhone 16 pro Max that goes without problems but my (old) 2016 MacBook has problems that are unusable. The Wi-Fi remains connected but there is no type of connection either local or internet. Once connected, the connection disappears spontaneously after a few minutes (about 2). I tried several solutions doing different tests including a Wi-Fi vpn connection with wpa2 that worked a few more minutes to give the same problem. I strongly believe that the software is buggy, if I disconnect the Wi-Fi and reconnect it works well for a few minutes to go down again. I trust in an ASUS support soon otherwise I have to return the device. I'm surprised they didn't notice such a serious problem. Is there anything I can do to report and solve the problem?
03-26-2025 10:49 PM
Hi @Netkar ,
Thank you for your inquiry.
To better understand the MacBook Wi-Fi connection issue with the BT8 router you are experiencing, please perform the following tests and provide information:
If the problem persists after trying the above steps, please assist in using the system's built-in problem reporting function to submit the relevant information.
Please follow the steps below to report the issue, and we will assist you:
Additionally, please send us the following information via private message: product serial number, the time the problem report was submitted, the email used for the problem report, the time the issue occurred, the MAC address of your device, and a network architecture diagram of your current environment.
If your network is down, the UI page will generate a link for downloading offline data. Please click the link to download the data, compress it into a ZIP file, and provide a cloud link for us to analyze.
Thank you for your cooperation.
