ZenWiFi BE14000 Mesh Syslog error messages
tfhoughton
Rising Star I
Just got a BE14000 3 node mesh to replace an aging Linksys system. Working well so far....with 2 items I need to address:
1. Range is not what I expected, but that it not the topic of this item.
2. The System Log shows errors:
Jan 3 15:28:54 roamast: [ERROR]maclist mis-match
Jan 3 15:28:54 rc_service: roamast 12300:notify_rc restart_roamast
Jan 3 15:28:54 rc_service: waitting "restart_roamast" via roamast ...
Jan 3 15:28:56 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[17] Wcid[2] Tid[0] ACTN[2] SN[3533]
Jan 3 15:28:58 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[73] Wcid[9] Tid[0] ACTN[2] SN[859]
Jan 3 15:29:04 roamast: ROAMING Start...
Jan 3 15:29:08 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[17] Wcid[2] Tid[5] ACTN[2] SN[1117]
Jan 3 15:29:13 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[72] Wcid[9] Tid[5] ACTN[2] SN[3159]
Jan 3 15:29:27 kernel: 7990@NOTICE.CFG,rai0,RTMPAPPrivIoctlSet() 3217:
Any advice on how to address these errors would be greatly appreciated.
Tom
20 REPLIES 20
Hi @tfhoughton ,
thank you for the information you've provided.
We've passed your details on to our relevant backend team for analysis.
Please be patient and wait for any updates or messages from us.
Hi @tfhoughton ,
Thank you for your inquiry.
We have confirmed that the WIFI@ related log files you mentioned are used to record detailed information about the interaction between your device and the Wi-Fi network, and they are considered low-level system records.
If you are not currently experiencing any Wi-Fi connection or related issues, you do not need to pay special attention to these log files.
Thanks for the info. I was just concerned about the ERROR messages. The Wifi seems to be working OK. I am having issues with two Nest cams resetting WiFi connections frequently. This results in the camera appearing offline. This did not happen with my Linksys configuration. Any thoughts on this?
Question: How often does the syslog refresh itself (i.e., zeros its contents and starts anew)?
Thanks again
Hi @tfhoughton ,
we have sent you a messege via PM box, kindly check and confirm.
Hi..an update... Got the latest firmware last night: ZenWiFi_BE14000_3.0.0.6_102_56746-g97576e4_216-gb7f4b_M7EC
A snip of the syslog error messges. The WiFi errors are still present. Note the:
hapdevent: hapdevent_proc_event(347): ra2: Assoc 3c:e9:0e:c6:32:38.  According to CoPilot this is an ASUS MAC address.
Jan 17 10:52:42 kernel: ra2: received auth req from 3c:e9:0e:c6:32:38 (alg=0, seq=1, status=0)...
Jan 17 10:52:42 kernel: 7990@NOTICE.HIF,ra2,hwifi_add_sta() 249: entry 00000000ecca1ac6, sta :00000000e1747acb, wcid = 23
Jan 17 10:52:42 kernel: send auth resp to 3c:e9:0e:c6:32:38 (alg=0, seq=2, status=0)...
Jan 17 10:52:42 kernel: ra2: received assoc req from 3c:e9:0e:c6:32:38 ...
Jan 17 10:52:42 kernel: send assoc resp to 3c:e9:0e:c6:32:38 (status=0)...
Jan 17 10:52:42 kernel: WiFi@NOTICE.FW,StaRecAutoRateParamSet() 514: wcid(23), PhyMode(78), RateMode(6), 256QAM(0), AmpduF(0), MaxPhyCfg: MODE(2) Flag(0) STBC(1) GI(1) BW(0) ldpc(1) MCS(7) Nss(0)
Jan 17 10:52:42 hapdevent: hapdevent_proc_event(347): ra2: Assoc 3c:e9:0e:c6:32:38
Jan 17 10:52:42 kernel: 7990@NOTICE.FW,ra2,UniCmdStaRecRsp() 160: PeerAddr(3c:e9:0e:c6:32:38) Wcid=0x17 (23), Cipher=0x20, BssIndex=0x2
Jan 17 10:52:42 kernel: 7990@NOTICE.FW,ra2,UniCmdStaRecRsp() 165: KeyIdx=0x0, igtk_key_idx=0x0, bigtk_key_idx=0x0
Jan 17 10:52:43 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[65] Wcid[40] Tid[0] ACTN[2] SN[3985]
Jan 17 10:52:43 kernel: 7990@WARN.MLME,ra0,ap_peer_disassoc_action() 4030: ASSOC - 1 receive DIS-ASSOC request
Jan 17 10:52:43 kernel: WiFi@NOTICE.MLME,ap_peer_disassoc_action() 4037: ASSOC - receive DIS-ASSOC(seq-1660) request from 3c:e9:0e:c6:32:38, reason=8
Jan 17 10:52:43 kernel: 7990@NOTICE.MLME,ra0,MacTableDeleteEntry() 1627: (caller:txcmdsu_dbg_init+0xbe0/0x20d8 [mt_wifi]): wcid 23 =====
Jan 17 10:52:43 hapdevent: hapdevent_proc_event(381): ra2: Disassoc 3c:e9:0e:c6:32:38
Jan 17 10:52:43 kernel: 7990@NOTICE.MLME,ra0,_MacTableDeleteEntry() 2068: Del Sta:3c:e9:0e:c6:32:38, Wcid 23 del=1
Jan 17 10:52:43 kernel: 7990@ERROR.PROTO,ra0,ba_resrc_rec_add() 2290: Wait-RRO
Jan 17 10:52:44 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[64] Wcid[40] Tid[5] ACTN[1] SN[339]
Jan 17 10:52:46 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[217] Wcid[27] Tid[5] ACTN[2] SN[352]
Jan 17 10:52:46 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[232] Wcid[29] Tid[0] ACTN[2] SN[88]
Jan 17 10:52:51 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[216] Wcid[27] Tid[0] ACTN[2] SN[77]
Jan 17 10:52:54 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[64] Wcid[40] Tid[5] ACTN[2] SN[339]
Jan 17 10:52:54 kernel: WiFi@ERROR.PROTO,uni_event_rro_del_chk() 2578: S4-Event BA REC_BA_Status[5] Seid[65] Wcid[40] Tid[0] ACTN[2] SN[3989]
