Asus zenwifi be14000 upload speed issues
lunatix4
I recently upgraded to an ASUS Zenwifi be14000 and am having some issues with upload speeds.
My setup
I have ATT BGW320 router setup in IP passthrough for 1ghz speed connection. Asus router is connected from the ATT router Lan port to the wan port on the ASUS router by cat 6 cable, new. I then have the Lan connection on the ASUS router with a cat 6 cable to the switches for the home. First issues I noticed was incredibly low speeds both up and down. So, after reading a forum I turned QOS on, Lan speeds returned to normal. Wi-Fi was then tested by moving to different channels and finding the best ones. Download speeds are great at above 800, but upload speeds are horrendous. I get 23 max on upload and it doesn't matter what changes I make the Wi-Fi remains terrible for uploads. I have fast DNS setup under wan per support person I spoke with and am on the 8.8.8.8 and 8.8.4.4 settings. Is there something I'm missing that is affecting the upload speeds?
1 ACCEPTED SOLUTION
Accepted Solutions
msirota
New update: While I was shopping for a replacement, I found this deal on an unmanaged switch from Netgear, $14 including free shipping, so I figured I'd give it a try -- and sure enough, like others on the Internet, it solves the problem. Clearly the Asus WAN port and the ONT are not negotiating correctly.
I still have a replacement coming and intend to return this, but if @Aureliannn_ASUS or ASUS second tier support wants to get back to me, I would prefer to get this working without needing this additional cost and complexity.
For those who are fine with tolerating the additional cost and complexity, putting a switch between the main unit and the ONT does seem to solve the technical problem, though it doesn't address the lack of support from ASUS.
20 REPLIES 20
alexeiyo
@luntatix4:
Have a very similar issue with the same hardware.
Mi plan is Verizon Fios 300Mbps. With Asus BE5000 getting 320Mbps download and 360Mbps upload speed.
After "upgrading" to BE14000 getting 320Mbps download and 2.5Mbps upload. No matter what changes I make to the network settings.
msirota
I have the same problem. Asus Zenwifi BE14000, purchased today.
If I plug my computer directly into the FIOS ONT, I get the full 300/300 performance I'm paying for. If I plug the BE14000 main unit into the ONT using the very same cable, and run a speed test straight from the router or via a computer connected wired or wirelessly, I get the same 300+ Mbps download speeds but am limited to between 1.73 and 4.42 Mbps upload (ran several tests as I kept trying things).
I saw a forum post somewhere in which someone suggest putting a switch between the two because the problem is that the 2.5G port on the BE14000 is specifically incompatible with the FIOS ONT, but I don't have a compatible switch and don't intend to go spend more money, I'll just return this and buy some other brand if this is the actual issue.
Anyone have a way to determine whether this is really the problem? I'll try calling ASUS support tomorrow, they're closed now.
Other info: QoS is disabled. Tried several cables, all work with the computer connected directly and none work with the BE14000. Firmware is up to date, Verizon tech was here today and verified the ONT is up to date and functioning properly (and this is validated by getting the proper speeds with a computer connected directly).
I have debated the same solution with a switch in the middle even though I am ATT vs FIOS. If I'm unable to get it working I'll be following the same solution with returning the device. I've run networks for years at home and different ones, but so far the ASUS and Netgear solutions seem to be failed software endeavors with nox fix actions or support. ASUS support really seems to be lacking for a company trying to win customers back. I like the mesh because I get no disconnects but the upload speed is a major concern.
Brief follow up — my experience began Monday. I spent 70 minutes on the phone with ASUS support on Tuesday, which ended up in the ticket getting escalated as expected. The next tier should call me back within two days, but it wasn’t today (Wednesday), so hopefully tomorrow (Thursday). I’ll let you know what I learn….
