Difference between "mlo fronthaul for clients" and MLO in wireless tab RT-BE92U
jimmysofat6864
I want to turn on MLO but I don't know what the difference is between these two options for MLO. If I have MLO enabled in the wireless tab but leave "mlo fronthaul for clients" disabled, will my phones and laptops and other devices still support MLO and will it still work?
Valdo
Asus has an issue with naming. Fronthaul , backhaul, uplink, downlink...
I think! that when you disable MLO fronthaul the connecting device will not able to select the wifi band. But if you set a different SSID for 2.4 and other common for 5G &6G then will work in case that fronthaul is indeed uplink...
