01-03-2025 08:38 AM
My Internet Provider likes it's users to connect using their supplied and modified Fritzbox, which allows them to run greater investigation into connectivity issues.
Currently I am running 3 XT8's (one as a router and 2 wired nodes), with the router directly connected to the ONT.
Has anyone managed to setup their XT8 in Access Point(AP) mode / AiMesh Router in AP mode connected to a Fritzbox. I have tried on multiple occasions, but without success!
01-05-2025 10:02 PM
Hi @worldtraveller2 ,
Thank you for reaching out to us!
Regarding the issue of setting up your ASUS XT8 in AP mode or AiMesh router AP mode, we recommend verifying the following steps:
For detailed AP mode configuration steps, please refer to the FAQ link provided below.
[Wireless Router] How to set up access point mode? | Official Support | ASUS Global
[AiMesh] Does AiMesh router support as Access Point mode? | Official Support | ASUS Global
Thank you for your understanding and support.
