Mesh components question
Lenthal
Currently own a TUF-AX5400 and a RT-AC68U. Need to build a mesh network in a multi floor home.
My first thought was to use the AX5400 as the main router and add something like the ZenWifi bd5’s , Bt8’s or the GT6’s Will this work? Will the Zen routers mesh with the AX5400?
another idea is to buy an upgraded single router like an AX6000 and use my existing router to mesh to it.
Trying to understand how to configure the mesh network properly.  Appreciate any thoughts.
1 ACCEPTED SOLUTION
Accepted Solutions
jzchen
Zen Master II
Highest spec unit should be placed as primary "router".  The lower spec ones added to AiMesh as "nodes".  ZenWiFi models do mesh with ASUS routers.  The webpages layout/configuration is different/takes getting used to...
jzchen
Zen Master II
