09-11-2025 11:48 AM
Hi guys
I have a GT-BE98 router. We have a fairly large house and we'll soon be needing wifi outside that very house. I was thinking of buying an extender. Maybe the Asus RP-AX58
Does anyone know if this setup is any good ? any experience using that extender ?
Hope you can help
Solved! Go to Solution.
09-14-2025 04:53 AM
Thanks for all your help, I really appreciate it 🙂 I bought the one you suggested and it works like a charm 🙂
09-12-2025 08:19 PM - edited 09-12-2025 08:28 PM
The BD5 Outdoor works as an access point and will also work with an optional wired POE switch - meaning it could require only one Ethernet cable with no other connections. The BD5 Outdoor also offers a number of mounting solutions.
09-16-2025 10:40 AM
Wired AP is definitely a solid connection. For me, i'll try to avoid placing network devices completely outdoors, there are damage risks during extreme weather.
