ZenWifi BT8 will not connect to my ISP - need VLAN setting
CraigB
Hi have just purchased the ZenWIFI BT8 and it will not connect to my ISP (IINET - Australia)
There help desk has advised that i have to set VLAN to" ON"
But in the Web Portal (ASUSRouter.com) there is not option to do this.
Any suggestion or have i just purchased a Boat Anchor ?
5 REPLIES 5
jzchen
Zen Master II
Did they give you a VLAN ID, (VID)?  No info is given that this setting is necessary on FTTH service on their website:
https://help.iinet.net.au/set-byo-modems-ftth
ASUS (moved/hid) VLAN in the LAN section under Advanced Settings -> LAN -> IPTV (tab)
Under LAN Port - Select ISP Profile if iiNet is not an option choose Manual Setting.
Internet VID should be the first line with PRIO but these numbers are needed from them if the iiNet profile is not there and Manual Setting is needed.
https://www.asus.com/support/faq/1011708/
SirStinkalot
Any success with this? I have just started down the same path. I’m on iiNet HFC NBN.
CraigB
yes this s sucesfull
MitchG
Wait, why am i being told the isp vlan should be filled in the WAN settings?😯
