02-27-2025 02:05 AM
I have a new router, RT-BE92U. From DHCP, I'm getting assigned IPv4 addresses, as well as an IPv6 address and DNS that I didn't set up. Where can I disable that? My IPv6 setting: Advanced Settings → IPv6 → Connection type → disable.
03-01-2025 03:53 AM
What's the firmware version? Flash to the latest if it is not already, hard/factory reset, then try again to disable IPv6.
03-02-2025 10:08 PM
Hi @Sampy ,
the latest firmware version 3.0.0.6.102_37506 has now been officially released.
Please update your device to the latest version and check if the issue persists.
ASUS RT-BE92U|WiFi 7|ASUS Global
If the issue persists after completing the above step, we recommend that you use the system reporting function of your router to send us the relevant information.
Please follow the steps below to report the issue, and we will assist you:
Additionally, please send us the following information via private message: product serial number, the time the problem report was submitted, the email used for the problem report, the time the issue occurred, the MAC address of your device, and a network architecture diagram of your current environment.
If your network is down, the UI page will generate a link for downloading offline data. Please click the link to download the data, compress it into a ZIP file, and provide a cloud link for us to analyze.
Thank you for your cooperation.
03-15-2025 11:15 AM
Hello, the firmware upgrade did not help, and the problem still persists. I couldn't find the exact report. I navigated to Administration → Feedback. I will send additional information privately.
04-02-2025 04:34 AM
Hi, were you able to check?
