two ASUS routers with two ISP providers (one connected to each) but not close to each other.
imutedu
Hello,
I have two ASUS routers. One is an RT-AX68U using one internet service provider (slower speed for work, basic task) on one side of the house. The other router is an RT-AX86U using a completely different ISP (faster for games, streaming.. i have kids). I have two for failover, I work from home and i got some kids that enjoy online gaming. I'm wondering if there is a way to AiMesh the routers but still leverage multiple ISPs? right now i have two separate SSIDs and I've configured each computer to use wifi and ethernet simultaneously so it can take advantage of two ISPs but this process is a pain to manage.  there isn't a location in the house where cable and phone lines are within the same location to make this a simple fix and im renting so i cannot drill into walls, etc.
Aureliannn_ASUS
Hi @imutedu ,
based on your issue, you can set up an AiMesh network with your two routers (RT-AX68U/RT-AX86U) while still utilizing multiple ISPs.
It is suggest that you update both devices to the latest firmware version.
And then you can follow the steps according to the following link.
[AiMesh] How to setup AiMesh system (Web GUI)? | Official Support | ASUS Global
It's strongly recommended that you put the AiMesh node between your AiMesh router and your existing dead zone.
