RT-AX88U and print server - doesn't woer as expected
ciemas
Hi everybody.
Some time ago (years rather than month) i bought router mentioned in the subject and after some time i decided to connect printer to it as it (asus router) suppose to have print server. My printer is samsung ML-2165. It took me whole day to struggle against asus firmware, unfortunately without success. I try even to borrow "windows" based computer from my neighbor (on day basis i use linux machine) to run print.exe program as advised by the asus router web interface - no luck 😞 . There is no way to use other printer connected to the router than asus said. It's pathetic 😞
If U're looking for universal, versatile equipment DO NOT BUY ASUS ROUTER. It works only with hardware supported and pointed by asus.
Best regards
Ciemas
Aureliannn_ASUS
Hi @ciemas ,
Thank you for contacting us.
After checking, we are sorry to inform you that we currently do not support the Samsung ML-2165 printer model.
To provide you with more accurate service, we recommend that you refer to the following list of supported models:
[Wireless Router] How can I use EZ printer sharing with ASUS wireless router? (for Windows OS only) ...
Printer Support List
