02-13-2025 01:07 PM
Dear ASUS Support Team,
I'm planning to set up a streaming PC with the following configuration:
The capture card operates using PCIe 3.0 x8, while the RTX 4060 Ti also utilizes 8 PCIe lanes when in use.
According to the specifications of the Asus ProArt B650-CREATOR, the motherboard provides two PCIe 4.0 x16 slots that can run in x8/x8 mode when both are occupied.
Could you please confirm if this configuration is fully compatible and will function as expected?
Thank you in advance for your help!
02-19-2025 11:06 PM
Hello @tsiko
Thank you for reaching out to us.
Based on the PCIe specifications of the ProArt B650-CREATOR motherboard and the Computer Interface specifications of the DeckLink Quad HDMI Recorder, both appear to be compatible in terms of installation interface.
However, for firmware, driver compatibility, and overall functionality, we recommend consulting the recorder's manufacturer to confirm whether this product meets your specific usage requirements.
