rt-ax55 disables static IP communications when NAT is disabled
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-29-2024 10:32 AM
I am not using NAT so when I disable NAT to use the static IP's the router stop communications with the network. What would cause the router to stop after NAT is disabled? It is running firmware version Firmware Version:3.0.0.4.386_52332
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-25-2024 10:12 PM
Hi @Asusme1 ,
Based on the information you provided, we would like to confirm if you have disabled the NAT for the WAN or else.
Are you trying to use a static IP to connect to the local network? Please help us confirm. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2025 03:08 PM
I am only using static IP and do not need NAT whichi I try to disable from the WAN setting.
- « Previous
- 1
- 2
- Next »
