11-26-2024 04:51 AM
Hi
Will a zenwifi BD 4 work with a ZenWiFi XD5.
I mean speak to each other. I know one is wifi 7 and other is wifi 6.
It a shame not to use it.
Thanks for any help.
11-26-2024 06:18 AM
Try adding as node the XD5 using Ethernet connection, then disconnect it.
4 weeks ago
Hi @organic ,
Thank you for your inquiry.
Yes, both ZenWiFi BD4 and ZenWiFi XD5 support AiMesh technology, and they can be used together. Whether you want to expand your wireless network coverage or improve network speed, you can easily achieve it through AiMesh technology.
You can find more detailed AiMesh setup instructions and frequently asked questions on our official website:[Wireless Router] How to setup ZenWiFi AiMesh system (Web GUI)? | Official Support | ASUS Global
