Networking
Forum Posts
New GT-BE98 Firmware 38984 Heads Up
The new firmware very slightly improved router to mesh node 6GHz front and backhaul stability. It also  slightly degraded 6GHz client to node and client to main router communications. Since I have been reliably using 6GHz client communication with me...
Alex52 by Star I
  • 14 Views
  • 0 replies
  • 0 kudos
Asus router WAN port no longer works suddenly
As the title says. The port just seemed to suddenly stop working. I use a spectrum modem and have so for a couple years and now suddenly the WAN port just stopped. I can connect the modem to other LAN ports and give internet access to my other hardwi...
pipers by Star I
  • 59 Views
  • 0 replies
  • 0 kudos
Asus Zenfi AX & VPN issues
So about a year ago, I setup an Asus Zenfi AX router with Proton VPN installed on itEverything worked fine for almost a year, and then about a month ago I started running into connection issuesSo I looked at everything and it seemed the VPN certifica...
RT-BE92U hidden network
 I have an RT-BE92U router. Why do I have a hidden network that I don't configure even after a hard reset.Where can I turn it off? The networks are separated (2.4G,5G,6G, 2.4G IOT)
AFC and MLO Update On GT-BE98 Pro With BE96U Mesh Node
After sifting through the GT-BE98 Pro Online "Network" menu I found how to get MLO working - partially.I use my GT-BE98 Pro main unit with a BE96U Mesh node and an AXE11000 Mesh node.You can turn on MLO in the GUI settings, but you need to use the On...
Alex52 by Star I
  • 199 Views
  • 0 replies
  • 0 kudos
Asus DSL-N16 Clock can not be changed.
 Asus DSL-N16Latest firmware and factory reset can not solve it. Changing time zone also does not help. It is stuck at 2011 with a warning of "Reminder the system time zone is different from your local setting"How can I fix this problem?
RT-BE88U IGMP Proxy not working on SFP WAN + IPTV
Hi, I'm trying to make work my router with a IPTV, having SFP as primary WAN. Internet connection is working and live channels in deco TV are also working. But menus and zapping is too slow or even not working. I think the problem is there is no IGMP...
