08-03-2025 01:00 AM
Hey All,
This is for the WAN side, not LAN side QOS.
Just got a ZenWifi BT10 to move to Wifi 7. I've been using my existing XT12 perfectly well direct to the ISP with a PPPoE connection. The PPPoE connection requires a specific VLAN but, I that option is missing from the BT10.
Here's the kicker; on the BT10 I **sometimes** see the QOS box when making changes to the PPPoE but, it vanishes at almost the same time - like it thinks I don't need this option so it will hide it.
Any ideas, please?
edit: updated to latest firmware. 802.1Q isn't mentioned in the official manual and neither is VLAN.
08-06-2025 12:44 AM - edited 08-14-2025 12:22 AM
Hi @Stuza ,
we’re very sorry to hear about the issue you encountered. To help us further investigate the problem, please submit a feedback report through your router's web interface using the steps below:
If your internet connection is unavailable during the issue, the interface will generate a "Download offline data" link. Please download that data, compress it into a .zip file, and upload it to a cloud service (e.g., Google Drive) for us to analyze.
In addition, please send us the following details via private message:
Thank you for your cooperation.
08-15-2025 07:56 AM
I believe the same function can be achieved using VLAN on the LAN settings?
