06-26-2023 11:37 AM
Hello!
I've been having a lot of issues with the Asus connectivity (First Bluetooth, now Generic Mobile Broadband Adapter #7 and Viscosity Virtual Adapter V9.1)
First my Bluetooth would randomly disable itself, this prompting the 'unknown usb device descriptor request failed' to appear.
Now I noticed in the Device Manager that the Generic Mobile Broadband Adapter #7 & Viscosity Virtual Adapter V9.1 & V9.1#2 are giving error codes.
Generic Mobile Broadband Adapter #7: This device cannot start. (Code 10)
Viscosity Virtual Adapter V9.1: Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
Viscosity Virtual Adapter V9.1 #2: Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source. (Code 52)
When I select the drivers to update, it says they're up to date.
When I use the Intel Driver & Support Assistant, it says everything is up to date.
Anybody have solutions?
06-26-2023 08:43 PM
Hi @the_bullet_01 ,
based on your question, could you please clarify if you are experiencing any issues with ASUS router?
If your issue is related to a laptop, we have a dedicated discussion forum for laptop users where you can seek assistance.
You can refer to the link provided below.
06-26-2023 10:12 PM - edited 06-26-2023 10:13 PM
Not the router, no.
Just a regular Spectrum modem/router.
But I'll see if I can find that laptop discussion forum and repost it there!
06-26-2023 10:34 PM
Hi @the_bullet_01 ,
Below link is the Laptop discussion forum. Thank you.
08-21-2023 12:32 AM
