on
01-29-2024
05:53 PM
- edited on
10-07-2025
05:29 AM
by
ZenBot
[Wireless Router] GT-AX6000 2.5Gbps FAQs
GT-AX6000 has dual WAN/LAN 2.5Gbps / 1Gbps Ethernet ports
Notice: the related information needs to be confirmed with your Internet Service Provider (ISP)
1. If I connect a 1G cable modem to the 2.5G/1G port configured as a WAN port, will it function at 1G?
2. If I connect a 2.5G cable modem to the 2.5G/1G port configured as a WAN port, will it function at 2.5G?
Note: Please confirm with your Internet Service Provider (ISP) for the broadband speed information.
3. Can combine dual 2.5G port for WAN aggregation on the GT-AX6000?
Only 2.5G WAN port can be used.
WAN aggregation lets you to combine a 2.5 Gbps port and a 1 Gbps port to unlock up to 3.5 Gbps of WAN bandwidth.
Please refer to [WAN] How to enable WAN Aggregation on ASUS Router? to learn more.
Note: When the Internet service provider (ISP) provides a bandwidth greater than 1G for a single network line, it can use the 2.5G WAN port.
Settings: Go to router settings page(WebGUI) > Quick Internet Setup > Advanced Settings > Wireless router mode (Default) > Select 2.5G WAN, then finish setup process.
Please refer to this FAQ for how to set it [Wireless Router] How to enable WAN aggregation on RT-AXE7800?
4. Can combine dual 2.5G port for Link Aggregation on the GT-AX6000?
Using LAN aggregation you can bond two 1 Gbps LAN ports together to create a 2 Gbps LAN connection.
Please refer to [Teaming Port] How to setup link aggregation on ASUS router?
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
