9 hours ago
I am upgrading my FTTP broadband from 900MB/S to 2GB/S and I couldn't find out if my Asus RT-AX58U would be able to cope with that speed over PPPoE?
The reason I ask is that my ISP is sending me a new router as the old one they provided cannot cope with that speed, and I have long since replaced their router with the ASUS.
Thanks in advance.
Solved! Go to Solution.
8 hours ago
looks like the tech spec shows the RT-AX58U WAN port is 1Gb, so you won't be getting the 2Gb you're paying for.
https://www.asus.com/us/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax58u/techspec/
8 hours ago
8 hours ago
Thanks for your response. I guess ill have to use the ISPs router then 😢
