3 weeks ago
Hi , I had a gt 98 router ai mesh with 2 xt8 but always disconnected after sometime.i try factory reset but still the same problem I used wireless ai mesh. anyone known what the problem?
3 weeks ago
Hi @Snakesc ,
Thank you for providing detailed information about the disconnection issue with your ASUS GT-98 router and AiMesh network consisting of two XT8 nodes.
We recommend that you try the following steps:
If the above methods still do not solve the problem, please provide the feedback log so that we can assist you further.
you can submit a feedback form Web GUI (http://www.asusrouter.com).
1.Connect your device to your router and log in to Web GUI(http://www.asusrouter.com)
2.Find “Administration,” and tap “Feedback”
3.Fill in your region, email (required field), ASUS Service No./Case No.(not required),Select the feedback problem and description.You can also write down comments/suggestions. More details might help us to analyze the issue you have encountered in a faster and more efficient way.
4.Read the agreement and click “I agree.”
5.Tap “Send” to submit your feedback.
Then provide the product serial number, the time of submitting the issue report, the email used for filling out the issue report, and the time when the issue occurred via private message.
