02-26-2025 07:50 AM
RT-BE92U main router (3.0.0.6.102_37504-g4be1e5e_1088-g416ff_BB0B, latest)
RT-AXE7800 mesh node over Ethernet (3.0.0.4.388_25142-g8c68976, latest)
tri-band wifi on both. When guest wifi is enabled, lose connectivity on mesh router Eth ports. IP assigned but can't ping any internal IP. Wifi including guest one continues to work like charm on both main and mesh.
Any ideas ?
02-26-2025 09:04 PM
Is Ethernet Backhaul Mode enabled? If not try with it enabled and report back....
02-27-2025 06:57 AM
02-27-2025 08:14 AM - edited 02-27-2025 08:34 AM
@the_birdy Check Lesco Bill wrote:Hi,
Any ideas ?
The issue might be caused by guest network isolation, preventing Ethernet access. Check if guest isolation is enabled and disable it. Ensure DHCP is only handled by the main router, and set the mesh node to Access Point mode. Consider updating or downgrading firmware and rebooting devices to resolve conflicts.
02-28-2025 06:02 AM
Thanks.
Limited guest NW to main router and mesh LAN ports started to function as expected. Need to try with downgrading but culprit seems to be guest wifi.
