Wednesday
Hello 🙂
so I currently use a FritzBox 7590 AX v2 and would like to use my ASUS Router (ASUS GT-AX11000 ROG) as a repeater - in Repeater mode.
Unfortunately this is not working. The router is “Connected” in repeater mode (see https://www.asus.com/support/faq/1036082/) but has no real connection to the internet. Websites are not working, ping to 8.8.8.8 or google.com do not work either.
I have called ASUS support Germany and sent an email “to be forwarded to Level 2 Support” explaining my problem in detail. The answer I have received was not really helpful, as they just said to reset my FritzBox or contact AVM (manufacturer) to figure out where the issue is.
Resetting does not help and replacing the FritzBox with Routers of other manufacturers does not solve the problem either. The repeater mode just refuses to work no matter what.
What can I do ? How do I get it to work ? Have I missed anything ? I did reset all routers multiple times (also using hardware reset button).
