I have an issue in WOL from my access point.
redwarez
Please refer below image link. ​https://ibb.co/wQsX9JQ
PC1 is perfectly working the WOL function on main router GT-AX11000 but PC2 is not working WOL from AP RT-AC68U. When I connected PC2 to main router GT-AX11000 directly through a separate cable its worked perfectly. How the magic packets cab send to the AP from main router on the existing setup. Please support.
Note:- WOL is initiating from main router ASUS GT-AX11000 bcs the access point is working under mesh configuration.
AP Configuration:- https://ibb.co/PZwCHkg
jzchen
Zen Master II
I believe you may need to set the GT-AX11000 to Router mode.
MarkWood21
PC1 is perfectly working the WOL function on main router GT-AX11000 but PC2 is not working WOL from AP RT-AC68U. DGME Paystub When I connected PC2 to main router GT-AX11000 directly through a separate cable its worked perfectly. How the magic packets cab send to the AP from main router on the existing setup. Please support.
To enable WOL for PC2 through your AP (RT-AC68U), ensure the AP forwards magic packets correctly by enabling broadcast forwarding. Since the AP is in a mesh setup, check that the main router (GT-AX11000) supports forwarding these packets through the mesh network. Additionally, setting a static ARP entry for PC2 on the main router might help.
