Adding XT8 to Mesh with ethernet = blue led
pvanosta
I have a few ethernet jacks throughout my home (2 on the ground floor, 2 on the first floor). I have a Mesh of XT8's dotted around the house. The two which are on the ground floor, are connected to the ethernet LAN and ultimately via a switch to a Fiber modem.
I have individually tested the ether ports by walking around with a laptop and connecting it directly to each ethernet port. I have 1GB down and 1GB up on every port in this way (limitation of the laptop).
I have added an XT8 to the mesh by putting it next to the master and connecting the WAN port to the switch. All is well. White led => good to go.
I take it upstairs and plug it into the ethernet port there (which I already know gets GB signal) and power it up. Blinking blue LED.
Side note: I still get the speed benefit in that room, both via wifi and via ethernet to one of the LAN ports. But in the mesh it remains invisible / not connected.
What am I missing / doing wrong?
11 REPLIES 11
jzchen
Zen Master II
I'm honestly not sure what is happening.  But I suggest you try deleting it from AiMesh, hard/factory resetting it.  Place it upstairs and connect it via Ethernet, then try adding it as an AiMesh node.  I find 90+% of the time this works, and you don't have to move the node as it's already where you want it.
pvanosta
Just tried that. Didn't work. Got the fast blinking blue led and could not find the node to add to the mesh. Unplugged ethernet and it rejoined the mesh.
If unplugging the Ethernet caused it to rejoin the mesh it was still registered as an node?/unsuccessfully removed from the Mesh/not hard reset:
https://www.asus.com/us/support/faq/1046973/
pvanosta
Thank you, will try that next. Good catch.
