01-22-2025 01:03 PM
So, I have an AIMesh network with 3 AXE16000 routers and 2 AXE7800 routers... wired connections, 5ghz and 6ghz networking are working perfectly. However, the 2.4Ghz network which was originally working is no longer working and I can't seem to get it working no matter what I do. I see the network in a wifi scan, but I can't properly get devices to connect to it and/or connect and router to the internet. Sadly I have older devices that only work with 2.4Ghz networks so need to get the 2.4Ghz networking working again. Does anyone have any steps I can take to get wifi working? I have tried different versions of the firmware (older and newer) and lots of settings with no luck. There has to be something I can do to get 2.4Ghz wifi working again.
01-22-2025 07:31 PM
Hi @Swellvue ,
Thank you for providing the detailed information.
To better assist you with this AiMesh 2.4GHz network connectivity issue, we recommend trying the following steps:
01-23-2025 07:58 AM
I have done all of this. Nothing seems to be fixing this 2.4Ghz networking problem.
02-09-2025 07:23 PM
Hi @Swellvue ,
If you have any issues/ questions/suggestions when using ASUS router, you can submit a feedback form Web GUI (http://www.asusrouter.com).
1.Connect your device to your router and log in to Web GUI(http://www.asusrouter.com)
2.Find “Administration,” and tap “Feedback”
3.Fill in your region, email (required field), ASUS Service No./Case No.(not required),Select the feedback problem and description.You can also write down comments/suggestions. More details might help us to analyze the issue you have encountered in a faster and more efficient way.
4.Read the agreement and click “I agree.”
5.Tap “Send” to submit your feedback.
Then provide the product serial number, the time of submitting the issue report, the email used for filling out the issue report, and the time when the issue occurred via private message.
