Device / Family settings won’t stick - RT-AX58U via iOS App
jstein
We have a RT-AX58U router that we’ve have been using with no problems for a while — until last month.
Now whenever I try to change Family or Device settings via the iOS app, the settings will not stick. They just revert back to what they were. This happens automatically, for instance, when I…
  • block a device’s access; (see attached)
  • withdraw or add a device from/to a Family group;
  • add or change a Time Scheduling;
  • delete or change a Family group…
The change seems to happen, but 3 seconds later reverts back.
This basically makes these family / device features worthless, and I’m this close to just buying a different router.
To try to fix this, I’ve…
  • power cycled the router;
  • updated firmware;
  • updated the iOS app;
  • deleted and reinstalled the iOS app.
And, I’ve gotten in to the browser based admin controls but the same features sren’t available there afaik.
Any other suggestions?
Screenshot of app with devices after they were just set to disabled then automatically reverting to enabled:
jzchen
Zen Master II
One suggestion I noticed you haven't tried is a hard/factory reset, then reconfigure from scratch.  (Sometimes firmware doesn't fully install correctly)...
Aureliannn_ASUS
Hi @jstein ,
Regarding the issue you are experiencing, please refer to the FAQ below for troubleshooting steps and ensure that you have followed the instructions accordingly. Thank you.
[Wireless Router] How to set up Family(Parental Controls) via ASUS Router App? | Official Support | ...
