Connect WiFi6 and roaming between ZenWiFi XD5
EmmanuelE
Hello folks,
I just bought a ZenWiFi XD5 (3 pack), and I would like to know how I can get WiFi6 on my devices obviously in the compatibility devices. Only I can see 2.4Ghz and 5GHz signals.
Also, how I can enable roaming between 3 ZenWifi nodes. I mean when I are connect in the principal room and I going to upstairs still are connect in the node (principal room) and not change to the second floor node.
I wait your help.
Regards.
5 REPLIES 5
jzchen
Zen Master I
WiFi 6 (ax) is 5 GHz.  If you are looking for 6 GHz that is either 6E or WiFi 7, which the XD5 does not support.
The three XD5 should be set up as an AiMesh?  If they are then roaming is automatic.  The XD5 may be too close to each other that roaming from node to node doesn’t occur.
Hello jzchen,
ohhh ok noted!!!
The three XD5 should be set up as an AiMesh? <---  Yes..
I understood both situation, thanks for the clarification. If I have other doubt I will post on this forum.
Regards...
EmmanuelE
One more thing,
As you can see the picture attached,
How I can connect the node (2do piso niños) with node (Principal)..???
Regards..
