4 weeks ago
I have A pair of ASUS ZenWiFi XT9 AX7800, and an RP-AX56. In the context of accessing the internet, everything is working perfectly. It doesn't matter what AIMesh node you're connected to, everything is great.The LAN is broken.
3 weeks ago - last edited 3 weeks ago
I can only guess/speculate that with Windows you need to enable UPnP on the ASUS router and device discovery on the Windows machines. I'm afraid I have zero experience with PLEX servers.
3 weeks ago
Hi, thanks for taking the time to respond. I would say this is not a Windows issue or a PLEX issue. This is an issue with basic internal networking, managed by Asus routers.
As mentioned, even ping doesn't work over the private network unless certain conditions are met. It's also new behavior, as everything worked as expected until 2 days ago.
Again, thanks.
3 weeks ago
I'm sorry to read this is happening. There was a firmware update 9/23 version 3.0.0.4.388_24668. Could it be this auto updated and is causing the new issue? Have you tried/Maybe try reverting to the prior version 3.0.0.4.388_24609?/.
3 weeks ago
Possibly. That would make sense, to be honest. I opened a case with Asus, but haven't heard back. If this continues much longer, I may try to revert. Thanks for the advice.
