can't connect rp-ax58 to rt-ax88
udiburg
Just purchased my RP-AX58 in order to extend my WIFI network and connect it as AiMesh to my RT-AX88.
I'm struggling with it for 2 hours now.
Can't make it connect to each other.
Read already all the manuals that can be.
I really need some help here.
Thanks.
#rp-ax56
1 ACCEPTED SOLUTION
Accepted Solutions
udiburg
The issue was solved by connecting the node with network cable to the router, configure it a Mesh and then disconnect it and place it in it's location.
Aureliannn_ASUS
Hi @udiburg ,
based on your issue, may I ask whether you have try hard reset two router?
You can refer to the following link:
[Wireless Router] ASUS router Hard Factory Reset - Method 1 | Official Support | ASUS Global
Have you make sure that both router and node is close to each other?
May I ask have you update the router firmware to the latest version?
May I ask whether you're using wired or wireless connect?
Try using wired connect to confirm the issue.
udiburg
