asusrouter.com portal down?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-02-2025 12:14 AM
asusrouter.com or router.asus.com are not responding, please sort out asap...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-02-2025 02:14 AM
Which router model? Older routers try 192.168.0.1 (if I remember correctly), newer routers use 192.168.50.1 .
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-03-2025 12:29 AM
Hi @teekoo74 ,
To better assist you with your issue, we would like to gather more information.
Please confirm the following:
- Router model: What is the model of your router?
- Refer to FAQ: We recommend that you refer to the following FAQ, as there may already be a solution to your problem:[Troubleshooting] Why am I unable to access my ASUS router’s settings page? | Official Support | ASU...
- Try using HTTPS login: You can also try logging into the router management page using the HTTPS address. Please refer to the following link: [Wireless Router] How to access my ASUS router’s web GUI setting page via HTTPS? | Official Support ...
