10-11-2023 01:21 PM
asus pce-ac88 not performing 2100mbs on 5ghz. Does someone know what settings should i change?
10-13-2023 06:39 AM - edited 10-13-2023 06:41 AM
So first thing is check Device Manager to make sure every device has proper device driver installed, no “!”. I am not very familiar with Windows 11 but seems right click Windows Start Menu should have Device Manager option. If any ! are there try uninstalling and resinstalling the driver. (Hopefully it self resolves).
Second I also found this software for it (64-bit default but choose from the drop down accordingly):
https://www.asus.com/us/supportonly/pce-ac88/helpdesk_download/?model2Name=PCE-AC88
10-14-2023 02:17 PM
Some driver files went missing and it solved it. I had to replace some of it manually,but thank you for your time<3
