07-15-2023 08:09 AM
Dear all,
I have an ASUS ROG Zephyrus G14 laptop and ASUS MB16 portable monitor. My laptop has only one 1x USB 3.2 Gen 2 Type-C support DisplayPort™ / power delivery and I used this one to charge my laptop and use my monitor. However, I need to switch the cable to use my monitor using my batteries.
Question: is there a dual USB-C cable to charge my computer and use my portable monitor at the same time? OR a hub where I can charge my computer and use my monitor at the same time?
thank a lot!
Solved! Go to Solution.
07-18-2023 06:11 AM
thanks for the response. I will buy this adaptor and get back to you.
and I will read this pdf as you suggested and get back to you
07-17-2023 12:56 AM
Hi @sendero ,
may I ask whether your MB16ACE has no image?
ZenScreen™ MB16ACE only requires a single USB connection for both power and video transmission from your host device.
It features an innovative hybrid-signal solution with native support for USB Type-C™ (USB-C™) connections, and uses an installed driver* to support USB Type-A connectors for full compatibility.
When choosing a USB-C hub or dock, make sure it supports power delivery (PD) and has a display output compatible with your portable monitor (such as DisplayPort or HDMI). Look for a hub that specifically mentions support for charging and display output simultaneously.
You can refer to the following product specification.
ZenScreen MB16ACE|Monitors|ASUS Global
ROG Zephyrus G14 GA401 | Gaming laptops|ROG - Republic of Gamers|ROG Global (asus.com)
07-17-2023 06:07 AM
when I connect the cable from my laptop to the monitor, everything is OK. The main problem is that the port is the same one that I use to charge my laptop. Thus, after 1-1.5 hr, I need to disconnect the monitor and recharge my batteries
do you happen to have some potential hubs/cables to recommend?
thank you!
07-17-2023 06:17 AM
I found this one in amazon. Do you think it would work?
07-17-2023 06:34 PM
Hi @sendero ,
have you try to use the original USB Type-C cable and USB Type-C to A adapter to connect the USB monitor and the system?
After connecting using this method, may I ask if you are able to charge and display at the same time?
You can refer to "2.2" in the following link.
ASUS_MB16AC_MB16ACR_MB16ACM_MB16ACE_English_20191008.pdf
Consider the compatibility requirements and specifications of your laptop and portable monitor when choosing a USB-C hub, splitter cable, or alternative connectivity options.
Ensure that the selected solution supports the necessary power delivery and display capabilities.
