System: Windows 10
Battery or AC: all
Model: Expertbook P2451FA
Frequency of occurrence: always
Reset OS: yes
Screenshot or video:
Detailed description:After buying a laptop and installing Windows, cooler immediately began to make a whistle, not very loud, but after a long work it becomes unpleasant. In the application MyAsus I set the "quiet" mode, it became a little quieter, but still exist. At the same time, the sensors show the temperature of all components not higher than 30 Celsius. Also I have another model Expertbook B1, where the fan is generally turned off and turns on only sometimes, but in the P2 model it works always and makes noise. Is it possible to solve this problem so that the cooler turns on only for cooling or does not make such a sound?
